wa8yxm
Dec 27, 2016Explorer III
The fuse size depends on the wire size more than anything I have 3 "Fuses" (one is a circuit breaker)
1: 40 amp, 10ga stranded wire feeds a distrubition panel next to the driver's seat which in turn feeds a bunch of stuff (Radios, Fans and such) it is an anderson power pole panel (West Mountain Radio)
2: 80 amp self resetting breaker (Factory installed) the main "House" fuse.. My converter is also 80 amps.. Same make as yours, just bigger, also has wizard.
3: 300 amp. Feeds the inverter, nice BIG welding cables 0000 gauge as I recall.
So the answer depends on wire size.... The bigger the wire the bigger the fuse.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
