Terryallan wrote:
It is gonna move some, and believe it or not. The bigger it is the more it will move.
However. Once you have snugged the stabs down, and set the X chocks. The only thing you have let that you can do, is to use jacks beside the wheels. To take some weight off the suspension. With the weight on the suspension. It will bounce every move you make.
This. You can prevent back and forth motion with Xchocks and they help a lot. But as long as the suspension, with SPRINGS, is holding the weight, there will be vertical bounce.
