wa8yxm
Jun 11, 2014Explorer III
"Some rest areas have some restrictions"
IN fact in some areas EVERYTHING (other than a licensed campgrond) is restricted by Govermental decree.. City, county or State law may prohibit overnighting in a parking spot...
Otherwise, to unhook and jack or not.. Use the comfort test..
The key appliance in your RV that needs to be level if sitting is the fridge, it can be up to around 3 degrees off (May be a bit different depending on the direction) I am uncomfortable long before the fridge is. So if you are comfortable walking around and sleeping inside the trailer.. You good.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
