GoldwingCapeCod's avatar
Aug 20, 2013
Storing a class c
We live in a condo which has a HOA. They will not allow, nor do we have space to park a 28-30 ft class c for any duration.
So my plan is to store. There is a facility near by with gated outdoor storage. Last i checked about a year ago, cost was about $75 a month. We are however in the northeast so it would be outside during the winter, December thru march. Or store it in the southeast or Southwest so we can get away and visit it for a couple of weeks during the winter.
Can one store long term at CGs. Do they have annual rates? Pros and cons.
So much to learn.
Mike S
  • Keep in mind that an RV is build for outside:)
    Yes, it's nicer if you can keep it covered, and I'd highly recommend that you at the very least, get the tire covers, to help reduce the UV deterioration of the tires.
    Will that local place allow you to plug in, to keep batteries charged? It's still a good idea to visit it monthly, to run the genset. Bring along a 1500w space heater, to put a load on the genset, to "exercise" it. If they don't have an outlet you can use (20A would be fine), you can charge the batteries when you run the genset every few weeks.:)
    I'd also suggest that if you have a heavy wet snowfall, that you try and get the snow off the roof of the RV as soon as you can. It would help to take the load off the tires (snow gets heavy), and help to keep reduce any damage from melting/freezing snow/ice on the roof....but don't lose sleep over it, if you happen to have a blizzard, and you can't get to it.
    As far as being there in the winter....as long as you winterize it properly, it shouldn't be any problem. I imagine you'll see lots of other RVs stored there during the winter too.
    You may want to consult some CGs for storage, but you would probably feel more comfortable with a security gate protecting the RV....though that in itself isn't a guarantee. :(
    Some (not all) CGs will offer long term storage rates. You'd have to call and see what they charge, and what they offer (will they allow the RV to be plugged in to keep the batteries charged?).
    Storing it down south and visiting it is not a bad idea, but are you going to use it as much as you'd want. Would the plan be to take a Fall trip down south, and drop it off, then fly (or rent/tow a car) home until you want to take the next trip? You may miss out on some nice weather trips in the Spring?
    Lots of people are doing just what you plan to do, so I'm sure there will be a wealth of information.
    We are fortunate that we can park (and plug in) our MH on the side of our house.
    The closer the RV is to your house, the more you'll use it, or visit it, and that is good for both YOU and the RV:)
  • Yes. Parks like Ocean Lakes in Myrtle Beach, SC will store it. They do it on a quarterly basis, but will pro rate it. I want to say it was around $55/month earlier this year. Lakewood next door does the same thing. The good thing about Ocean Lakes is that they have an RV service department if you ever need anything done to it.
