canadiancamper2's avatar
Oct 09, 2018
storing for winter
Ok so this has probably been posted over and over again but Ive spent hours looking for the answer to my questions and cant seem to find what I need. so here it goes hopefully someone has some input. I just picked up a wolfpack 24pack14+ about a month ago. our season ends mid October found a park that's open one week more then the rest and gonna push the season. after that the trailer is being winterized by the dealer not gonna take that in this year already taking on a lot of info. after that I have a place to store it for the winter not what I would call preferred parking by any means but I spot that was cost effective and big enough for the trailer. the area has deep grass but is level. so now the questions aside was hitting the grass with a weed wacker is there any point in putting down a tarp under the trailer to keep the grass down? what about mouse traps I was reading that putting them under the trailer isn't a bad idea? also should everything be taken out, what can be left in over the winter? is it a bad idea to drop the support jacks to lessen the load on the suspension for the winter? I know its a lot to read and bunch of things asked hopefully you guys got something for me.
  • I would removed any food, bedding, towels, throw rugs. If you have mice, they will use any loose fabric for bedding, they may also tear into other fabrics that you can't remove, so you do want to do something to try to prevent them. Have heard Freshcab mentioned a lot. Haven't researched to see what that is.
    We did not remove our battery, used the battery disconnect switch and the house battery which was older was bulging/had frozen and we had to replace it. Engine battery was fine and the coach started right up. If we were to store it over winter again, we would remove both batteries and store them in a warmer place.
  • Well, the information is in these forums many many times over. This is your rig, and it's your responsibility to look after it.
    It takes about one hour to do it right. Your dealer might be busy and not get to yours before it freezes solid and cracks all kinds of things.
    It matters not about the grass under it, protect yourself and look after what is in it. Drain the water, clear the tanks, blow it out or put in the antifreeze properly. Let it sit on it's wheels, do not lower jacks.
    Absolutely disconnect the battery, crack a vent just a tiny amount and all will be just fine without too much worry.
  • Cutting the grass down is a good idea. The tarp can help with moisture coming up from the ground but it will kill the grass so check with the property owner first. Mouse traps can hurt other animals so watch what you use and any bait for traps WILL attract other animals like raccoons so don't use any bait. The jacks are only for stabilizing not to lift the trailer of the suspension. You need to remove anything you worry about freezing and any food.
    I would also park it on some treated wood boards like 2x12 long enough for both tires and raise or lower the front so water can run off easier.
