Grumpy374
Aug 08, 2013Explorer
New here also, with a new class c. From researching and reading other posts here, you have to block both wheels/tires. If you don't, all the weight from that side/axle will be resting on the one tire you have the block under, which is not good for that tire. You wouldn't run on one tire, so don't block only one tire.
Grumpy
Grumpy
About RV Newbies
