andrew_the_newbe wrote:
Sorry, should have been more specific. I bought my trailer through private party. The seller mentioned sway bars as I was pulling out of the driveway but made it sound like it wasn't necessary. And my Tahoe is rated to pull 7100 lbs and the trailer weighed down is 6400. Does the Tow package on my vehicle not apply to this? Again, if I'm asking stupid questions I apologize, still brand new to this.
Yes your tow package applies, IF you are using a WDH. If you will look on your receiver. You will see 2 weights stamped there. One will be prolly 500lbs tongue weight, and 5000lb trailer weight, and will have "weight carrying" before, or after it. That is what your receiver can "carry" with out a WDH.
there should also be another weight stamped on it. Will be something like 900 lbs tongue weight, and 9000lbs trailer weight, and have "weight distributing" before or after it. That is what your receiver is rated to carry with a WDH.
However. That is NOT the tow capacity of the Tahoe. Only the weight, the hitch is rated for. As you have stated. Your tow capacity is 7100lbs. GM as well as all manufacturers put the same hitch on every vehicle in it's class, and so the hitch is rated for the tow capacity of the highest rated vehicle it goes on.
BTW. Once you have the WDH setup correctly. There should be NO trailer sway. It should just follow right along. You will feel it back there, but it won't be pushing you around. Once you have it right. Then add sway control. The dual cams , and straight line hitches are good.
And IF you haven't got a brake controller. The Prodigy is a very good one to get. With the tow package. It should just plug in, But I'm not sure about GM vehicles.
