draknor's avatar
draknor
Taking our new-to-us 5er out for the first time!
Super-excited! A few weeks ago we bought an '04 Hitchhiker, and we're finally getting it out to a local campground this week for a few days, before our first real "trip" for Memorial Weekend!!
I've done a bunch of reading & research, and just want to jot down our plans and see what others think about getting us and our new rig ready!
Last night we parked the RV out front of the house to do some prep work:
- Removed the giant tube TV :)
- Replaced the water heater anode rode
- Flushed the water heater tank with that wand thing
- Filled up the freshwater tank + water heater (which is off) & added a teaspoon of sodium dichlor to sanitize it.
- Ran all the faucets so the chlorine gets to all the pipes & fixtures
- Let the whole thing sit over night
Today, once we get it to the campground I'll dump the tank, refill & dump again to flush, then refill one final time for use (no water hookup at the camp site).
It's a bit cool this week in the midwest, so I'll get a chance to check out the furnace at night :)
Will experiment with packing supplies, figuring out all the different fixtures & switches -- we went through everything during the PDI but it's been a few weeks.
One thing I need to figure out - when I turn the water pump on, it runs continually (I left it running ~5 min last night). Talked to my dad - he said it should only run briefly & then turn off, so might have a pressure leak somewhere. Or some valve is open that shouldn't be. Didn't have time to investigate last night.
Not sure if I'll get to it this week, but I've got an EMS 30A hard-wired unit arriving tomorrow, so I want to get that installed and in the process, make our shore-power cord removable. I don't like how it's crammed into this little nook behind the circuit breakers - would rather coil it nicely & transport it in the basement.
Also need to replace a burned out drive light.
Another future project will be to reseal everything - I've got some Geocel ProFlex RV on order (local Camping World didn't have any).
And then will need to figure out what roof maintenance I need to do.
Lots to learn :-)
  • Depending on whether your HW heater is full or empty the water pump will run for a few minutes to fill the tank. Once the HW tank is full and air is purged out of the lines the pump should shut off. If not, start checking for leaks. Mo leaks? Then it is possible the check valve in the pump is bad.
    How are the tires? More than 5 years old it is time to replace, 3 years if they are ST tires.
  • "- Flushed the water heater tank with that wand thing"
    The same wand you would rinse the black tank with?
