jstaffon's avatar
jstaffon
Teflon Tape or Plumbers Putty?
For the past several years, I've been using teflon tape on the threads of the anode in my Suburban water heater to keep water from leaking out of the tank. This year, I bought a plumbers putty stick and coated the threads prior to installing my anode. I noticed it sealed much better than the teflon tape and didn't require so much torque to seal. Last year I had an issue with the tape. I had to tighten the anode tighter than I liked in order to create a seal. Many of the "How To" videos on YouTube tend to use the teflon tape. What's the recommended one to use? Thanks in advance!
  • Threads in drain hole and on anode rod are 'tapered' so that they seal against each other.
    I suggest you get a 3/4" NPT nipple made of steel and run it in drain hole to chase and clean threads up.
    Screw in by hand then tighten, loosen, tighten some more, loosen, tighten more etc until threads are clean.
    If reusing anode rod......clean up threads with a stiff wire brush or wire wheel
    Then use teflon tape or plumbers putty.......either will work
