zippyphil wrote:
I am thinking about going solo for a while and have some questions. I think a 25' RV is physically big enough for living but I think I want to take a small car with me. I know I will not need something over 30'. The car would be handy for side trips. Has anyone towed a small car with a 25'? is it too much of a strain?
1 buy a 30' class A or C so towing is OK
2 buy 25' with no car and call it a day
phil
To answer your question directly usually it is less of a strain on the MH drive train on a smaller Class A than a larger heaver one. If you think about it a 30 ft Class A has the same engine and transmission as a 38 ft one, only much lighter so your total weight is less pulling a hill. Most have hitches that will tow 5000 lbs. I would get a 30-32 ft class A with at least one or two slides or a full wall slide and a small tow car less than 3000 lbs. I think a 25 ft Class A would be too small for you. Also I would look for one with full basement storage (not the little cut out doors) and one with at least 80 gals of FW unless you plan on staying in FHU cg's every night.
