Jrogers83's avatar
Jrogers83
Tips and insight for new uses purchase?
Hello all,
I've always wanted to buy a small RV and travel the east coast with my two girls (6 and 10) while they are still young. I've recently been looking in TX at some new models that were a steal compared to the prices here in CT. I've always been nervous about buying vehicles of any kind used with fear of breaking down. It's just me and my two kids, my husband passed a few years ago.
I came across a 2003 (dont know the exact model yet, going to look at it today) with 50,000 miles on it being sold by someone I know for 12k. It's a little outdated but looks in great shape! They are claiming its mint. For the price, I'm thinking I can get a couple years out of it, get the RV experience in and then if we really like it buy a new one and continue.
I dont know much about RV's. I dont know how much they break down or at what point they become unsafe to be driving across country. I realize that I'll have to get it inspected and I realize that it may need a couple things and I'm sure RV repair isn't cheap, that's fine. I'm basically asking for any pointers or insight that you all want to throw my way. Does this seem like a good deal? Thanks in advance!
https://www.dropbox.com/s/iin8nqnnau1rf9k/16581.jpeg?dl=0
https://www.dropbox.com/s/vuy5uut2k3zyqyv/16571.jpeg?dl=0
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    With one or two minor exceptions (Related too boot) I'd not call a 2003 "Outdated" but then I'm sitting in a 2005.. Same exceptions. but I've upgraded.
    Televisions: 2003 came with a CRT boat anchor. Unless the prior owner has replaced it with a modern WIDE SCREEN ... with ATSC Digital (over the air) capability that would be my first upgrade. If you need I can discuss how to do it but I'll need photos of your current TV install.
    The TV antenna. Nost 2003 would have a Winegard Sensar II or III. this is the classic crank it up and rotate it "Batwing style" RV antenna it is the 2nd best RF antenna sold in the USA. To make it the best you buy the WINGMAN (About 30 bucks) and put it on. Tools needed.. Ladder, Fingers and optionally a pair of pliers (common slip joint) Job involves removing some rubber "Feet" (just pull 'em off) Line up the holes and insert some push pins included. That's it folks.
    (IN some cases you may need to do some trimming).
    Next upgrade also antenna is to replace the wall plate with the light. 12 volt outlet. switch and antenna connection.. YOu replace it with the Winegard Sensar PRO. (About 100 dollars) You will need a screwdriver and possibly a 7/16" open end wrench (11mM) Everythign else should be simple.
    That is really about the only "Outdated" things you will have. Or might have.
    THere may be a few maintenance issues.. (I Mean at 12 years old I had to replace the water heater tank, Batteries may need replacing, Check the age on the tires. 8 years replace 'em.) but that kind of thing is
    Routine maintenance for with the exception of brakes and tires and the like, any house.
  • gbopp wrote:
    Welcome to the forum. If you don't know anything about RV's, now is a good time to learn. Read this forum, and others, ask lots of questions. Your idea of 'mint condition' is probably very different from the seller.
    It would be wise to hire a mobile RV tech to inspect the RV you are seriously considering.
    Water leaks are a killer for any RV. A small leak not fixed quickly can do a lot of damage. So, the roof definitely needs inspected.
    Tires are another major item. On RV's tires usually age out before they wear out. Just because they have plenty of tread and look good does not mean they are safe. Learn how to read the tire code to determine the age.
    There is a lot to learn about RV's but, it's all fun stuff so don't be intimidated.
    Ask a lot of questions and don't be in a big hurry to buy.
    Use your search as a earning experience.
    I agree with the above for the coach items. I would probably have a mechanic go over it. We bought a slightly used 8-year old B+ to take to Alaska several years ago. Had our mechanic change all the belts, hoses, fluids and filters. The coach made it over 15,000 without a blip.
    Enjoy! Looks like a really nice coach, but have it checked out.
    Dale
  • Welcome to the forum. If you don't know anything about RV's, now is a good time to learn. Read this forum, and others, ask lots of questions. Your idea of 'mint condition' is probably very different from the seller.
