Harvard
Apr 22, 2016Explorer
jason26 wrote:Harvard wrote:
With the exception of a coastal highway it gets very hot in the part of the country you are planning to travel. A proven vehicle cooling system is a must, for example, do you know that your fan clutch works properly?
I wouldn't know. Was planning to get the dealership to do a once over before we go. I'll make a note of that.
Typically the fan clutch cuts in (making a loud roar) when the engine coolant gets hot. The coolant temperature then drops very rapidly. When the coolant temperature drops to a normal level the fan clutch cuts out. If the hot conditions persist the coolant temperature will slowly rise again and the fan clutch cycle is repeated.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
