2012Coleman
Aug 20, 2013Explorer II
Tvov wrote:Well then google the TT mentioned and check it out. Once you see the size of the TT and the AC unit installed in it - yes in the wall, you will understand my point. I know someone with a similar setup, so I'm not just guessing.
I don't think I've ever seen a wall mounted AC unit. Why would it run any different than a roof mount? It certainly will be much easier if maintenance is needed. I can see that maybe a fan might be needed to move air around.
About RV Newbies
