CincyGus
Aug 20, 2013Explorer II
Snowman9000 wrote:
What is the towing capacity of your Ranger? You don't want to be maxed out with a travel trailer. Towing a low profile boat at the max is one thing, but towing a big box behind you at max weight is pretty darn miserable.
See nothing wrong with the trailer for your stated needs. It will be quite the step up from your tenting experiences. Make sure it's within the towing rating of your truck and by that, I mean do the research, don't take the salesman's word for it. Payload and max towing ratings and payload is the one I would be most concerned about as that's the one that usually is the problem getting under with small trucks. Most ranger size trucks are limited to popups from what I have seen at campgrounds but you'll need to do the math.
The window air unit will be plenty for that size camper.
I would ask for a better battery capacity since your likely to be dry camping (two class 27's or two 6v) as part of the deal. this will give you the 3 days or so of power your looking for without recharging with a genny or solar if your conservative with your furnace use.
Good Luck and check back in if you need help!
About RV Newbies
