Bumpyroad
Aug 20, 2013Explorer
gcloss wrote:Tvov wrote:
I don't think I've ever seen a wall mounted AC unit. Why would it run any different than a roof mount? It certainly will be much easier if maintenance is needed. I can see that maybe a fan might be needed to move air around.
I was at an RV show last February and many of the small TT had wall mounted A/C units, including some Jaycos.
yep, years back when I looked at Casitas you could either get a roof mounted AC or one low under the closet area. if you wanted a full length wardrobe closet you had to get the roof one. also very common in popups.
one piece aluminum roof. looked like AC was controlled by a wall mounted thermostat.
bumpy
About RV Newbies
