- MikeDupontExplorer
Tire covers not only matter, the color/heat retention properties do also. At least so sez a retired tire company engineer.
https://www.rvtiresafety.net/search/label/Tire%20Cover - LynnmorExplorer II
larry cad wrote:
I will repeat my comment from earlier
We heard you the first time, we also read this from Goodyear:
Cover the vehicle and tires to protect from any unnecessary UV rays. - larry_cadExplorer III will repeat my comment from earlier:
Use tire covers, tires last 7 years. Don't use tire covers, tires last........7 years.
I have never heard of a single controlled test by anyone that disproves my statement.
Tire covers cost money, are a lot of work, and do nothing to improve tire life. - spoon059Explorer IIII occasionally use 303 protectant spray and generally try to keep direct sunlight off the tires when they are stored. Not sure if it helps or not. I replace tires within 5-6 years anyways, never seen any obvious UV damage in that time frame.
- Ro_n_JoeExplorer III use McKee's 37 Gloss Tire Gel (non petroleum or silicon containing formulation with UV protection additives). Love the stuff.
- NamMedevac_70Explorer III used the cloth covers when TT was on storage lots in Texas and Nevada. They were cheap to purchase and made me feel better. Also frequently applied 303 protectant to both TT and truck tires. Easy to apply and fun with no mess if done properly and stayed looking new and clean. Never any tire problems in 15 years of hard travel and storage. Replaced tires due to age and flats on road trips. Used mostly Maxxis TT tires. Cheap insurance to me. Cheers
Matt_Colie wrote:
According to Roger Marble (after his wonderful talk at an FMAC rally) modern ties are not subject to much damage from UV as the inhibitors are now included in the outer layers. What is an issue is heat. He was careful to point out that even in the northern climates, tires in the sun can accumulate a lot of heat. So, if you are buying tire covers, get the white or silver.
Matt
^^^ This. ^^^ - thomasmnileExplorerCouldn't hurt, may be helpful. One downside to using them in Florida, they gave cover to mud daubers and paper wasps cover setting up residence on the wheels and a nasty surprise to me when I removed them. Should have used the trailer more frequently than we did..... :)
- LwiddisNavigatorNot what Goodyear says, larry.
Lwiddis wrote:
Absolutely needed. Tire covers prevent UV damage.
So does the UV protection ingredient in the tire rubber added by the manufacturers.
About RV Newbies
