RJCorazza wrote:
moresmoke wrote:
The correct answer is get it loaded with all your stuff, then go to a scale and find out what the actual weight is. Then you can set your pressure based on the load tables. If it doesn't handle well with the full inflation your alignment may be off.
X2
This is the correct way to figure out the tire pressure YOU need. If possible get all four corners weighed to tell you what each set of tires is actually carrying, if that is not possible or easy to get, weigh each axle. Use the tire pressure chart and follow that. Your tires will like you and the rig should drive easily and straight.
