gbopp
Feb 19, 2016Explorer
Did you check all your battery connections for corrosion and make sure they are clean and tight?
Also check for a loose ground wire. I've noticed over the years that bad connections can cause a lot of weird problems.
Always check the cheap easy things first.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
