jpbuch9309 wrote:
Is there such thing as having too big of a generator? yes I know about all the portability problems but I like the "better safe than sorry" way. And I want to power my whole TT frig A/C (2) not not worry about anything.
The answers are Yes, Yes, Yes and No..
First 30 amps is 3600 watts tops, So any generator more than 40,000 watts is a waste of money (too big) and too heavy Less you go with a pair of 2000 watt inverter generators in parallel.. (Why do you want 4,000 watts for a 3,600 watt max trailer.. Well it seems they rate Generators on PEAK output, not sustained)
50 amp RV's are 12000 watt, However mY rv has only a 5500 watt ONAN on it. which provides all my needs.
NOw: The too bigs:
More watts than you can eat is simply a waste of money.. Unless you consider somethign I'll type later this post.
It is also heaver and physically larger and thus harder to store and transport.
It also eats more fuel
and in theory if it's way way too big, voltage regulation may suffer
These are the "YES" answers
But the NO is unless it is way too big (like 10 or more times what you need) a larger generator will work just fine, in fact cooler.. But you should aim to keep the generator close to the trailer needs for another reason too.
Run the generator at least 1/2 hour under at least 1/2 load evry month. A 100,000 watt generator will never hit half load on a 30 amp RV.. NEVER.. My 5500 can. (I dang near got to do the monthly run last week).
The something else:
If you are buying a portable Generator (or even a motor home) and own a Sticks and Bricks, consider what I did.. I had an electrician install a proper Generator Transfer Panel in my basement next to the new, upgraded SQuare D breaker box (The original was a PushMatic and I really don't lke those) with a proper INLET on the back of the house.
I came home from Chruch one day, Frosty the air-blonw inflatable snowman was sleeping on the job... Sure enough Power fail.. So down to the basement and get the big extension cord... Up stairs and plug OUTLET onto INLET and twist... Then uncoil the cord as I walk to the RV,, Plug into the RV (matching outlet I added) put Gen-turi on Generator and press buttons.. Hear the ClUNK (transfer switch) and back to basement.. CLICK and LIghts
Click and Freezer, Refrigerator, power to televisions and computers etc. power to Microwave, More lights, in fact all the lights in the house save one (Hall light we almost never used).. back upstairs and turn ON the hall light... Continue on ONAN power till hall light comes on (indicating mains power is back) Back down to the basement and clck everything back to MAINS.. Out to motor home and shut off ONAN.. Leave connected.
Really happened.
So if buying a portable.. Consider installing the transfer panel and buying enough for hte hosue.. NOTE: I used about 3400 watts per the on panel meters at the peak.
DO install the transfer switch DO NOT BACKFEED, ever.
