atreis
Oct 16, 2016Explorer
Minimal ... Part of the issue is that it doesn't change the aerodynamic profile of the back end of the trailer, which is typically a flat vertical wall. Aerodynamically, this creates a vacuum at the back of the trailer, sucking the whole combination backwards to try to fill that vacuum. If you could put on a topper, and round off the back, you might get somewhere (think: Airstream, although even a little rounding can help).
About RV Newbies
4,032 PostsLatest Activity: May 30, 2015
