NC Hauler wrote:
ReneeG wrote:
NC Hauler wrote:
ReneeG wrote:
NC Hauler wrote:
ReneeG wrote:
Time will tell for sure. As did our last ones that lasted 4 years.
Would it do any good to give you the name of the national RV tire experts that are all over the web? No, you've got it in your mind to believe what you want.
Yes it would be perfect for you to give the "national" RV tire expert(s) that are "all over the web"....a lot of so called "experts" on the web doesn't mean much unless they can PROVE they are just that, "tire expert"..We have several experts on this forum whom I would trust due to their expertise in the tire field and I too know a little about the industry as one of the products my company produces is tires/ I believe in data...I believe in facts, not "hear say".
Your 5er has a GVW of 14,000#. I would think it has 6,000# weight rated axles, "E" rated tires, I personally would have went with a Michelin XPS RIB (pricey, but how can one put a price on safety and peace of mind), or the Duravis R250 (believe that's correct, "me again" could correct me if wrong)...two tires far more robust than the Tow Max tires, don't believe me, go to a tire store, pick up a Tow Max tire like you have o your 5er and check sidewall thickness, see how heavy it is..now pick up a Michelin XPS RIB and check ridigity of the sidewall...proof is in the pudding:)
We've weighed ours fully loaded and it's no where near that, does have 6K axles and E tires. As for the expert, he's been mentioned here many times - Roger Marble at http://www.rvtiresafety.com/. We do believe our dealership as well, the service manager used to be in the tire business and he too provided his advice.
I only stated 14,000# GVW signifying the 6,000# axles...If I were running "E" rated tires, I would replace OEM with Michelin XPS RIBS, again, quite a bit more expensive then the tires you've referenced, but I know quite a bit factually about both tires and would go with the RIBS anyday over the Tow Max tires, but again, that's based on some pretty valuable data also...Glad your's work for you and hope they will continue to do so.
I do too. We can only go on the advice we were provided at this point. Thanks for the advice. I too believe in the best, we have a BD3 hitch after all, so we shall see.
Don't particularly agree that the BD3 hitch is "the best" just because it cost so much, but it would back my philosophy on tires....you get what you pay for, ie Michelin XPS RIBS compared to the Tow Max tires
I can respect that you have a different opinion and that's ok. That's what keeps businesses in business.
