bryris
Feb 18, 2014Explorer
Tow question
Looking at a 24 ft innsbruck lite. The empty weight is about 3700 and I assme loaded up, it'll be 4,500 or so. Looking to use my 2006 Explorer with 4.0L v6. It has 3.73 gearing and a class 3 hitch. Ra...
BarneyS wrote:
You are NOT going to like the way it tows. First the GVWR of the Explorer (the most the truck itself can weigh)is not 10,000lbs. That has to be the GCWR - the total that the truck and trailer COMBINED can weigh. Most 3/4 ton trucks have a GVWR of around 8800lbs or so so the Explorer has to be less than that. I suspect the GVWR is in the 6000lb range.
I suspect your Explorer is rated to tow 5500lbs. That means that you could tow a boat, flatbed trailer etc ok, BUT a travel trailer has a large frontal area and tow much differently than a boat. A 4500lb travel trailer will tax that Explorer to the limit and will not be fun even though it might be within the numbers!
Your profile says you are in Lakeland. I hope that is Lakeland, Florida where it is flat. If you stay in flat areas you might be ok as long as you don't try to go very fast. The engine, combined with the frontal area of the trailer will prevent going very fast and you will most likely not enjoy the towing process.
Sorry to be so negative but that Explorer, with its' small engine, short wheelbase, and soft suspension is just not designed to tow and will not make a good tow vehicle for a travel trailer. It may get you by but be prepared to go slow and stay near home where it is flat. I would not venture up into the upper parts of Georgia or other places where there are mountains or large hills.
Good luck. :)
Barney
