wanderingaimles
Oct 31, 2017Explorer
Chamerican wrote:wanderingaimlessly wrote:
The Armada's load capacity is sufficient as well with 1741 lbs, even with kids growing and "stuff" they want with them you should be ok. The only thing I would question is that if memory serves correctly, the Armada does not have a truck style frame. Unibody construction can work well and save weight in a car type of usage, but I have always been nervous especially in using a weight distributing hitch with unibody construction.
JM2C
Good point but part of why we're looking at the Armada is that it's body on frame. The 2017 was a redesign and based on Nissan's international equivalent and the Infiniti QX
Then I would think gear ratio and having enough grunt is the only real concern left. Any ideas on how well that tranny holds up to towing?
About RV Newbies
