Gr4ck3L wrote:
Hi Team,
T
Will add trans cooler and brake controller. I'm not knowledgeable in regards to the hitch receivers - is there a preference for WD/anti-sway on TTs?
Thanks all!
IF you have the tow package, and according to your first post, (" Hitch rcvr with 4 and 7 pin electrics ") you do. All Fords with 7 pins have the tow package. and the tow package includes a aux transmission cooler. To verify. Just follow the transmission lines out of the radiator. They will run into a cooler before they return to the trans.
