imadtchmn
Aug 06, 2014Explorer
GoPackGo wrote:
The dry weight of the camper does not matter. Your truck needs to be rated to tow the GVWR of that camper, which will probably be over 8,000 pounds.
The hitch weight will be higher due to that also.
I don't understand what the bumper has to do with it.
Tim
X2
WHAT!!!! I hope you don't tow it with the bumper. You need a frame mounted hitch for this trailer and a distribution hitch. Even then, I have to agree, if your truck is rated at 7500 lbs, you will be overweight.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
