wbwood
Jan 30, 2015Explorer
It's not so much the size as it is the weight. But the longer they are, the worse the wind will be on you.
Personally, I would look under 5000lbs. More around 4000-4500lbs. In the pop up world, the rule of thumb is 75-80% of your tow capacity. Meaning if your capacity is 5000lbs, then stay at 4000lbs loaded. It gives you some flexibility and room for error.
Just because you have "X" amount of towing capacity doesn't mean you need to go all the way to, nor should you.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
