camperfamily
Jan 30, 2015Explorer
We pulled a TrailManor 3023 with a 1998 V-8 AWD Explorer for a year. Honestly, our 1999 Ranger with the 4.0L 160hp V6 performed better. The suspension was always soft and the 3.73 gears and the auto tranny just didn't put it into a good spot in the power band. We used a Equalizer hitch on both combinations.
I'd suggest staying the the smallest trailer you can. No more than 21' preferably. Use a good WDH and keep your tires at max sidewall pressure. Add a trans cooler and keep on top of maintenance. Make sure to use a good brake controller, properly adjusted. If you choose according to your vehicles abilities it can be a capable tow vehicle. FWIW I'd consider replacing the rear springs on the Explorer. Even with minimal towing ours had weak springs, sagging on one side when we traded it last year.
Remember you will likely need to run a charge wire and trailer brake wire from the front to the rear.
Good luck.
Good luck.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
