- thehippieExplorer
RedRocket204 wrote:
this Is what I readthehippie wrote:
i’ve read not to use tow haul and exhaust brake when raining but not sure if towing on mountain though
Where did you read that? Makes me wonder if the context is lost or if the person who wrote it has any idea what they're referring to?
Don't use Cruise Control when raining, snowing or ice on the road. An engine brake is similar to gearing down your tow vehicle and that is something you always want to be doing in the mountains. You just don't want to be at a high rate of speed and then drop down two gears while on snow/ice or even rain as that can cause loss of traction. Everything in moderation when driving with questionable road conditions.
“WARNING
Do not use the tow/haul or engine brake features when driving in icy or slippery conditions as the increased engine braking can cause the rear wheels to slide and your vehicle to swing around with the possible loss of vehicle control.” - romoreExplorer III would suggest the writer is trying to limit liability in case the reader messes up. If the tow haul is engaged at high speed there will be an abrupt downshift when the vehicle slows down, common sense dictates that is not a good idea on slippery roads.
- donn0128Explorer II
Huh?
Tow haul can be engaged at any speed. Nothing happens until you alow or stop. When you start moving again the transmission will hold each gear longer to aid in bringing the load up to speed.
You really need to understand what a transmission tow/haul vs a diesel exhaust brake difference is. - Old-BiscuitExplorer III
donn0128 wrote:
Huh?
Really depends on the 'programming' used for tow/haul mode
If I am in 'D' doing less then 60 mph and push the tow/haul button the transmission WILL downshift from 4th (OD) to 3rd and then upshift when I go faster then 60 mph
Exhaust Brake...only engages when I let off of the go pedal.
But if in tow/haul AND EB...letting off of go pedal EB closes and transmission downshifts
Rain...not too worried
ICY/Slippery (snow) I would be cautious about using either - RedRocket204Explorer
Exactly. - LwiddisExplorer IIX2, BB.
- romoreExplorer IIIf I engage the tow/haul on my Ram at highway speed nothing happens until I slow to about 50 then there is an abrupt downshift and the ctd yells. I would rather that not happen on slippery surfaces, it works a lot better if I slow down first.
- BeakerExplorer
Tow haul only alters the transmission shift points so during acceleration it holds in gear a bit longer. Dry, rain, snow will have no effect on its use
Tow haul has to be engaged on my truck to use the "auto braking" or whatever its called to keep the truck slowed down on the downhill side. - Grit_dogNavigator
donn0128 wrote:
Huh?
Again donno, romore is correct. If you haven't had your trans abruptly kickdown a gear or 2 when running downhill and hitting the brakes (or even with cruise on sometimes) then your truck isn't working right.
The point is, the more slippery the road is, the less abrupt yours or the vehicles moves should be. TH and EB add to the abrupt moves period.
Bunch a armchair QBs here who don't understand their vehicles and apparently haven't driven in all conditions, or are at least not aware of all the things that can affect traction in less than ideal conditions.
Will any of this slide a truck sideways in the rain with a significant load in the bed? Not real likely, until you hit the right conditions. - AllworthExplorer IIWith Allison Transmissions (General Motors ONLY) Tow-Haul also engages the transmission downdhift feature which will ASSIST in holding down speed on downhill runs.
It is not an engine brake and is not as effective, but it certainly helps.
The basic answer to the OP's problem is: Slow Down!
On Edit: Do you folks not realize that each manufacturer programs their version of "tow-haul" the way they want. In case you have never noticed; Chevy is different from Ford which is different from Ram.
About RV Newbies
4,026 PostsLatest Activity: Jun 15, 2017
