thehippie's avatar
thehippie
Towing when raining on mountain
Do you use tow haul and automatic exhaust break when towing up or down on the mountain when it’s raining?
I have 2015 ram 2500 ctd and about 10,000 lb toy hauler
And do you also use sway control friction bar?
  • Tow haul only alters the transmission shift points so during acceleration it holds in gear a bit longer. Dry, rain, snow will have no effect on its use.
    Are you confusing tow haul with an exhaust brake?
    Again, on my Ram I always had the EB on if the truck was moving. Regardless of weather.
  • donn0128 wrote:
    Yes. I used tow haul anytime I was towing. Definitely saves on the service brakes.
    i’ve read not to use tow haul and exhaust brake when raining but not sure if towing on mountain though
  • Yes. I used tow haul anytime I was towing. Definitely saves on the service brakes.
