spikez wrote:
Would you mind expanding on the "no".
I think he means, you need more tow vehicle. I agree.
Time you get the TT, and the TV loaded. You will be over weight.
Secondly. Your tow capacity rating may NOT take into consideration the frontal area of the trailer. So it could actually be less.
Another thing, and you will need to check you owner's guide, or GM to find out. You will need a Weight Distrabuting Hitch to tow the 5200lbs. There is a chance your FWD based Traverse cannot use a WDH. Only GM can tell you that. But many FWD vehicles cannot.
