mindymd wrote:
One more question. What is the difference in the hybrid dry weight of 2678 lbs and a pop up dry weight of 2700 lbs? Is it because it is not as high or would it be the same strain on the minivan? The pop up is longer than the hybrid also. I am looking at a 2007 fleetwood.
brochure/website "dry" weights are fantasy numbers.
no trailer weighs its "dry" weight when it leaves the factory.
on smaller trailers, going by the GVWR is a good idea, since they generally don't have large CCC(cargo carrying capacity)numbers.
either going by the trailer's factory weight sticker amount(outside yellow sticker on newer trailer/inside white sticker on older trailers) or weigh the trailer, are the best options.
