jfkmk
Aug 13, 2014Explorer II
DrTanTodd wrote:
You will get a better rate on your insurance with Fiberglass siding due aluminum denting in hail. The downside of fiberglass is it is heavier.
As the owner of a vehicle that suffered $4000 worth of hail damage, I can assure you that the hail damage is typically on the horizontal surfaces rather than the vertical surfaces where fiberglass or aluminum would make a difference. I've never heard of corvettes getting an insurance break because they have fiberglass bodies!
The aluminum sided rv's seem to be at the lower end or entry level. I have one and have no issues with it. The cons is they can dent. The pros is they don't delaminate and they are easier to fix. Dents can be repaired easily where the fiberglass requires a more extensive repair.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
