melloftus
Jun 19, 2019Explorer
Travel Trailer dolly?
Hi All,
So I have read the couple of Post here RE:this subject and really couldn't find an answer to what I need. So last year I booked a camping site that we have only tent camped at years prior. When you are tent camping you have a different perspective then when you own a TT. Unsure if we could get our new to us TT down there we went up last month before the site opened to the public to check out the road going in and spacing to see if we could get the TT down there, where we wanted to park it etc. However there was still some snow on the ground so it made it a bit tough, Needless to say getting the trailer in/parked and out of the site might pose a challenge, my husband ever the optimistic thinks its going to be "fine" me the realist has some major concerns. We have a couple of options- Option A: back it down the road- there is a tight turn coming down and it is questionable if we can swing it into the spot hitched or B: drive it in and try to turn it around to get it to the spot we picked. The catch is I am not sure if we have enough room to get all the way turned around at the bottom, so one thought was to buy some sort of wheels to attach to the trailer hitch, disconnect the truck attach tow straps swing the trailer around then hitch back up to bring it to the spot.
I was looking at the Trailer Valet however we will not be on a concrete surface but rather dirt so I am not sure if that will work also with our hitch weight I think we will have to go with the more $$ XL version and we would never use this item at home to park the unit so I might be wasting money on a pricey gadget ... the wheel idea becomes a tough also as I unsure what I could buy that could handle our TT weight... suggestions much appreciated as I refuse to return to a tent!
Here are our TT specs: 2008 Fleetwood - Mallard 21CKS
Length:24.67 ft
Dry Weight 4,198 lbs.
Hitch Weight 636 lbs.
Fresh Water Tank Capacity 50.0 gal.(we will have a full tank) 416lbs
May another 300-400Lbs of stuff inside
Total weight appx 5000 +/- lb
Length:24.67 ft
