One of the handiest tools in my electrical tool box is an automotive test light
Most auto parts and hardwares have 'em
They look like an old fashion ice pick but the handle will be clear plastic (or tinted) with a light bulb inside and a wire with a clip on the end.
You ground the clip and probe for power BRIGHT = GOOD Dim or Dark = Bad
(yes I had dim once. quickly found the problem and excised it)
In addition to the test light I suggest round 25-50 feet of flexible wire 18-20 Ga is enough. PUt a ring terminal on one end (hole big enough for the test light clip to grip it) and a clip like the one on the test light on the other end.
if there is no known good ground near where you are probing.. use the spool of wire to go back to the battery negative
To test blade fuses (This shows how handy this is) Leave them right where they are and prove the two small windows one on each end on top
BRIGHT-BRIGHT = Good
DARK - Dark = no power to fuse no test
Dark - Bright or Bright Dark = Blown fuse
Now that was fast. you could check dozen fuses in the time it took to type this and I type fast.
