DutchmenSport
Jul 07, 2016Explorer
You've given pretty good arguments for both sides, a towable trailer or a drivable MH. Either way, buying used, you truly never know what you're REALLY getting until you get it and start using it. So, its probably a 50-50 toss up.
It boils down to what kind of camping you want to do. But, here's something you need to consider also.... insurance.
For the towable trailer, your insurance is covered when hitched up. (theoretically, you don't need to carry insurance on your trailer as it's covered when in tow). You can carry a separate policy. Then the separate policy, or rider, will cover damage when NOT attached to the tow vehicle, which costs much less than insurance on a vehicle with an engine.
On the other hand, with 2 vehicles with engines, you have to pay insurance for both. If this is the straw that breaks the camel's back, then you want to go with a trailer as your insurance will be less for both TT and tow vehicle, opposed to a Motor Home and the Nissan.
Another fine point to consider. When towing a trailer, you can usually back up with no issues. When towing a vehicle, especially on a dolly, you have to unhitch the pulled vehicle so you can back up. If you find yourself in a position where you have to back up, this might be anther straw to break that camel's back.
yes... lots to consider.
Others can chime in, pros and cons. In your situation, I still see a 50-50 coin flip. Good luck in your choice.
About RV Newbies
4,032 PostsLatest Activity: May 30, 2015
