et2 wrote:
valhalla360 wrote:
et2 wrote:
valhalla360 wrote:
et2 wrote:
We've had them all and now our MH. Went from a travel trailer to a fiver to get more room and storage space. A travel trailer can be matched to most pick ups up to a 3/4 ton. Don't know if these have auto levelers now but I'm sure things have come a long way. They are a bit more harder to line up to hookup getting the ball in the right spot.
Fivers can be bought that have as much space and storage as you want. But then the tow vehicle has to be considered very carefully. They're relatively easy to hook up compared to a TT. However you mentioned you're 70. I was one never to consider a MH as thought fivers had it all. But my back started giving me problems and climbing around the truck to hook things up was becoming bothersome. We had a 1 ton dually and a huge fiver. Loved it!
But now we have a MH and no more problems to worry about. Toad is easy to attach and I don't have to climb around to do it or get on my knees. Leveling is as easy as pushing a button inside after stopping. I'll never go back to the other two.
Tow vehicles should always be considered carefully regardless of trailer type. I've seen plenty of TT having issues going down the road with the rear squatting too much and swaying back and forth. Nothing rocket science about selecting a tow vehicle but it's not automatic with a TT.
I don't buy the MH is easier idea. Our neighbors just brought home a new 5th wheel yesterday. Once in the site, he pushed a button and the landing gear dropped. He pulled the handle to release the hitch and then pushed a second button and it leveled by itself. I can't see how that is much more effort than unhooking the toad and pressing a button to level the MH.
I never said it was easier. It fit my desires not climbing around a pick bed because of my back. Just something for the OP to consider being older.
But to touch on the subject of leveling, the MH wins hands down. I can do it from the inside moving 3 ft from my drivers seat, and not get wet from the rain. :)
Can't help but think of the wizard of oz when I get these comments...help, I'm melting. :B
I suppose if you plan to sleep in the cockpit seat hooked up to a catheter that's an important consideration to not have to move more than 3ft. Reality is most retired folks can pick nice weather days to travel.
Then again, how do you back into your site without leaving the drivers seat? Last I heard, you can't back up more than a few feet with a toad and certainly not make a turn while backing.
Not saying there is anything wrong with a MH just that the difference in effort setting up is negligible if you compare similarly equiped rigs.
There are sites called pull through, no need to back up. And if needed, I can unhook the toad in 30 seconds. You still need to exit the truck to access your RV. Not so similar to me.
If you are limited to pull thru, you can typically just pull thru with the 5th wheel and not bother to unhook. That leaves it as just the horrible walk back the trailer which leaves it at pushing a button for the leveler.
I will agree, if your idea of camping is never leaving the rig, you have a slight advantage.
