valhalla360 wrote:
et2 wrote:
valhalla360 wrote:
et2 wrote:
valhalla360 wrote:
et2 wrote:
valhalla360 wrote:
et2 wrote:
We've had them all and now our MH. Went from a travel trailer to a fiver to get more room and storage space. A travel trailer can be matched to most pick ups up to a 3/4 ton. Don't know if these have auto levelers now but I'm sure things have come a long way. They are a bit more harder to line up to hookup getting the ball in the right spot.
Fivers can be bought that have as much space and storage as you want. But then the tow vehicle has to be considered very carefully. They're relatively easy to hook up compared to a TT. However you mentioned you're 70. I was one never to consider a MH as thought fivers had it all. But my back started giving me problems and climbing around the truck to hook things up was becoming bothersome. We had a 1 ton dually and a huge fiver. Loved it!
But now we have a MH and no more problems to worry about. Toad is easy to attach and I don't have to climb around to do it or get on my knees. Leveling is as easy as pushing a button inside after stopping. I'll never go back to the other two.
Tow vehicles should always be considered carefully regardless of trailer type. I've seen plenty of TT having issues going down the road with the rear squatting too much and swaying back and forth. Nothing rocket science about selecting a tow vehicle but it's not automatic with a TT.
I don't buy the MH is easier idea. Our neighbors just brought home a new 5th wheel yesterday. Once in the site, he pushed a button and the landing gear dropped. He pulled the handle to release the hitch and then pushed a second button and it leveled by itself. I can't see how that is much more effort than unhooking the toad and pressing a button to level the MH.
I never said it was easier. It fit my desires not climbing around a pick bed because of my back. Just something for the OP to consider being older.
But to touch on the subject of leveling, the MH wins hands down. I can do it from the inside moving 3 ft from my drivers seat, and not get wet from the rain. :)
Can't help but think of the wizard of oz when I get these comments...help, I'm melting. :B
I suppose if you plan to sleep in the cockpit seat hooked up to a catheter that's an important consideration to not have to move more than 3ft. Reality is most retired folks can pick nice weather days to travel.
Then again, how do you back into your site without leaving the drivers seat? Last I heard, you can't back up more than a few feet with a toad and certainly not make a turn while backing.
Not saying there is anything wrong with a MH just that the difference in effort setting up is negligible if you compare similarly equiped rigs.
There are sites called pull through, no need to back up. And if needed, I can unhook the toad in 30 seconds. You still need to exit the truck to access your RV. Not so similar to me.
If you are limited to pull thru, you can typically just pull thru with the 5th wheel and not bother to unhook. That leaves it as just the horrible walk back the trailer which leaves it at pushing a button for the leveler.
I will agree, if your idea of camping is never leaving the rig, you have a slight advantage.
Of course thats if your fiver doesn't lift the rear wheels of your truck off the ground while leveling your fiver. Because you didn't unhook it and pull away. But that's OK your just trying to prove a point I guess, so common sense doesn't mean much. Sure makes for great conversation in the campground though.
I guess if you pay zero attention and are a general menace around machinery, that would be a concern. In that case, a MH is a better option but most times the pull thru sites are pretty level and it's not a concern. Then again many parks don't have pull thru sites anyway.
We rarely do it as we aren't in much of a hurry but a few times, we've dropped the landing gear and called it good if we are in late and leaving early the next morning. Never had an issue with lifting the back of the truck.
For a retired couple with the ability to pick their travel days, you really have to try to come up with the slightest advantage. Even if you do have to travel on a rainy day, it's just not that big of a difference.
Your the one that just said it was easy to push the button like it was no big deal, then just go into the fiver.
That would make you the menace as you obviously don't have auto levelers. So not sure why you're commenting like you know all about them There is a specific procedure to getting them to level the fiver which could include the fiver being unhooked from the truck. I had them on my last fifth wheel. Your speculation and misleading comments aren't helping anyone except maybe yourself.
For what it's worth we haven't had one problem getting pull through sites wherever we've gone. The Internet is a great tool for planning ahead. Being full timers that should give you pleanty of time to plan ahead too. Been across the USA and never had a problem. We've been in pleanty of paved pull through sites which have raised our MH wheels off the ground when leveling. Having a fiver is a good thing for you, no argument from me.
But since you and I have completely derailed this thread I apologize to the OP. My original comments were meant to be things to think about.
