handye9
Feb 15, 2016Explorer II
Your rating for "up to 4500 lbs" means ---- It is rated to tow 4500 lbs under perfect conditions. Those perfect conditions do not include passengers, pets, or cargo. As you add passenger / cargo weight, your available payload AND remaining tow capacity are going down, pound for pound.
If you put 700 lbs of people, pets, and cargo in the vehicle, it's max tow capacity is reduced to 3800 lbs. If you add a weight distributing hitch, that will take another 100 lbs.
Your Flex has a rating for what it can pull (up to 4500 lbs), a rating for combined truck / trailer weight, a rating for max weight on the Flex itself, and a rating for what the Flex can carry (that number should be on a sticker on drivers door post). If you load up on what it has to carry, you have to reduce the weight it has to pull. It can't carry a full load and pull max weight at the same time.
Some trailer sales people, will not even show you a unit that is too much for your tow vehicle. Some, are clueless about towing and will sell you anything you want to buy. Once you drag that thing off their lot, it's no longer their problem.
About RV Newbies
