bikendan
Oct 20, 2013Explorer
CA62Mini wrote:
When you say Van, are you refering to a full size van or minivan? Big difference in towing capacity. Don't know the towing capacity for your Dodge 1500. You might look at some of the hybrids with a solid wall rear bead slideout. Like the Rockwood Roo 23RS. GVWR 6145 lbs.
http://www.forestriverinc.com/TravelTrailers/Roo/default.aspx?model=roo&page=floorplandetails&floorplanid=4013&RVType=trailers
just for clarification, trailers like the 23RS are not hybrids, since they don't have any canvas. a hybrid is the combinations of canvas beds of a popup with the body of a travel trailer.
rear hard-sided bed slide trailers can be called "expandables", but then any RV with a hard-sided bed slide should be called an "expandable". the only thing different about these trailers, from other regular travel trailers, is that the bed slide is on the rear, instead of the side like other travel trailers.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
