Old-Biscuit
Jun 06, 2015Explorer III
IH_Fan wrote:
Thanks folks for your sage advice - greatly appreciated.
LarryJM: That is quite an ingenious device....thanks for the description and the photos. I can see benefits to that as you noted. Excellent idea!
Just remember Larry's caution about the hose/valve being reduced in size......
Drain hole is only 1/2" (Atwood with nylon drain plug) which is then further reduced using drain hose so sediments can remain/build up.
Hose/valve drain assembly should be completely removed and WH tank thoroughly flushed periodically to minimize deposits on element and tank .
About RV Newbies
4,032 PostsLatest Activity: Dec 23, 2025
