Old-Biscuit
Sep 22, 2016Explorer III
Just how accurate is your tire gauge?
Do you routinely have it calibrated?
Did you measure tire pressure the SAME way on all 4 tires?
Tire gauges.not accurate enough/never calibrated and measuring pressure is slightly different each time
Tire pressures are good to go..........Don't make this an issue or get OCD about it :B
Check tire pressures when COLD (not driven on for at least 2 hours)
1st thing prior to hitting the road. And if 50psi is called for..fill them to 50 psi (plus/minus couple pounds----close enough)
It isn't NASCAR
Which is another topic concerning that N2.
It isn't NASCAR
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
