jadatis
Sep 23, 2016Explorer
Many TT's have pressure advice based on GAWR( Gross axle weight rating), and if ST tires ( special trailer) the maximum load is calculated for 65m/h while most LT tires maximum load is calculated for 99m/h.
This means that ST tires have more deflection so more heatproduction then LT.
For these reasons its better to let me calculate an advice pressure for you , wich is probably higher then 50 psi.
If you have C-load tires ( probably because of 50 psi advice given) tiremakers dont allow higher pressure then 50 psi cold ( at 65/68 degr F), in earlyer days they allowed 10 psi extra.
To prevent overheating the 60 psi would be better for the tires in most cases , because mostly tires can yust bare enaug to carry the axle load together.
So in short , fill all up to 50 psi , mayby even 60 psi.
If you pressure device gives 60 psi , the real pressure can be, because of inacuracy , mayby even between 54 and 57 psi .
And this real pressure is what counts.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
