-------------------------------------------------------------------------------- Hey guys new here just pick up our new Rockwood Roo, I have everything set up for dry camping but the one thing I ca...
If you have a modified sine wave, MSW, inverter it could be using more power generating heat. People have said that things run hotter with a MSW inverter. If you have a pure sine wave inverter, PSW, then I have no idea. If you could check the output voltage from the inverter that might be low, but most voltmeters do not read MSW voltages correctly.
Many things do not run right with an MSW inverter.
