darsben
Oct 27, 2014Explorer II
scout266 wrote:Dakota98 wrote:
Take another pic of the area just above the shot you've already posted & post it also. I believe you have more options than first thought.
Also, were you intending on getting one of those 12 volt TV/DVD combo units ?
Yeah I wasn't sure whether or not to go for the 12 Volt tv/dvd combo or just get an AC current tv. I was leaning to one of the DC combos--that way we could use it if boondocking (no generator).
Any recommendations on one? I looked on amazon and every type seems to have mixed reviews
As been discussed to death on the forum most 110 volt tv's are 12 volts in disguise. Look for a 110 volt with an external transformer similar to a laptop cord. Check to make sure the transformer output is 12 volts. If it is 12 volt then just buy a cord to run from 12 volt outlet to the tv.
No "110 volt tv uses 110 volts. They all transform some with an internal transformer some with an external.
Best Buy and Walmart both have TV's as I describe
About RV Newbies
