wintersun
Oct 31, 2014Explorer II
Most reliable TV's by far are the name brand (Sony, Toshiba, Panasonic) 110AC ones and they can use a very small and cheap inverter to run off 12v DC power. We use a 19" Toshiba Combo with a built in DVD player that has outlasted 3 different 12v DC TV's that have each lasted a matter of months (Skyworth, Polaroid, Jensen).
Well-nuts are a safe way to mount a LED LCD TV to a wall. Best to verify with a small hole drilled (1/8" that the backing is there behind the paneling. If it is 1/2" particle board you will have what you need to support the weight.
These TV's use an industry standard VESA mount so you can buy the mount separately from the TV.
About RV Newbies
