So my TV is a 2013 Nissan Frontier, my TT is a 2015 Jayco 264BHW JAY FLIGHT SLX which is 29ft. My TV is good on the tow weight but can a TT be too long for a vehicle? I know the rule of thumb on whe...
I see a dry weight of 4300lbs, so loaded approx 5500lbs. I wouldn't call that over your limit, but probably the max you'd want to tow.
Sway is often too little tongue weight, also the WDH may not be set up properly. Some brands of hitch have the option to put a friction sway bar on both sides. With the length and weight trailer you have, it may be beneficial.
