rollindownthero's avatar
rollindownthero
Explorer II
Jul 07, 2020
Update since buying my first TT
I had posted at the end of April that I finally purchased my first RV, a TT. Wanted to give an update on how it's going so far.
Have now used it 3 times. Towing it seems to be fine, have had no issues with getting it hooked up, towing or sway. One thing is that I seem to have a problem when unhooking it from the truck. The first time the hitch came off the ball fairly easy when raised with the electric jack. The second time I actually lifted the back wheels of the truck off the ground before it came off. The 3rd time I greased the ball and inside of the hitch. I still seemed to have difficulty getting unhitched. Am I doing something wrong?
The second time I used it was on my way home and a tire blew. I had thought I had purchased everything that I needed to for it, except for stuff to change a tire. Where I pulled over was in front of an RV Resort. A man came out and asked me what was wrong. I explained I had a flat tire. He asked me if I had stuff to change it with, I told him no. He went to his truck and came back with everything to put the spare on. So now, I have everything, a lug nut wrench, I bought a ramp, a bottle jack, an air compressor, etc. So now I have what is needed to change a flat. Oh yeah, and a new tire.
This last weekend, the 4th, I was talking with some neighbors at the camp ground, they too had just got their first TT. The guy was telling me that he got a trickle battery charger for his. Is this something that is necessary to have? I always disconnect the battery when not in use.
The other thing is that I bought a Camco drinking water hose, it's suppose to be no kink, but it does! Also have a hard time getting put back in the container I bought to store it. Can one of those flex hoses be used to connect the water?
Otherwise, I am thoroughly enjoying the TT!!!
  • wing_zealot wrote:
    You don't need a trickle charger. I have never used one in over 20 years of camping. Either keep it plugged in when not in use or disconnect the battery when not in use. The battery will then stay charged. Instead of using a trickle charger, the guy can merely plug his camper in using a 30 amp/20 amp adapter.
    Be wary of this statement^.
    Unless your onboard charger/converter also has float/tender mode, you WILL overcharge your batteries just leaving them plugged in indefinitely when not in use.
    Many do, many don’t. Which do you have?
  • You don't need a trickle charger. I have never used one in over 20 years of camping. Either keep it plugged in when not in use or disconnect the battery when not in use. The battery will then stay charged. Instead of using a trickle charger, the guy can merely plug his camper in using a 30 amp/20 amp adapter.
