Sam_Spade
Dec 08, 2016Explorer
sofraj wrote:
Is this normal? I thought it should work stand-alone.
No of course it's not normal. You probably are feeding the trailer off the 12 V system in the tow vehicle.
YOU NEED A MULTI-METER, even if the current problem turns out to be something simple like a switch or fuse or improper connection.
And the maintenance charger should be a small AUTOMATIC tender type charger. A true trickle charger will not do.
About RV Newbies
