Old-Biscuit
Dec 08, 2016Explorer III
Blown reverse polarity fuses on converter......NOTHING will be able to power up the DC Dist Panel with fuses and individual DC circuits.
NOTHING....not the battery, not the converter and not the 'charge' circuit via umbilical cord
Main in-line fuse or DC circuit breaker on POS cable blown......again NOTHING will be able to power up the DC Dist Panel
OPs trailer battery was NOT fully charged using trickle charger
OPs trailer battery not being fully charged was unable to power up DC Dist Panel
OPs trailer battery being supplied a charge voltage via TV thru umbilical cord was able to supply DC Dist Panel......
Charge trailer battery and IT will supply DC Dist Panel w/o need for supplemental power from TV thru umbilical cord
Provided trailer battery charges fully and HOLDS a charge
(TV Charge line via umbilical cord can NOT support the load from DC Dist Panel.......wire from TV too small, too long and limited to maintaining a charge on trailer battery)
About RV Newbies
