wildtoad
Aug 26, 2014Explorer II
Most modern rv's route a furnace duct to the water tanks, pump, etc. if you run the furnace all the inside plumbing will be fine. If you expect a freeze and are hooked to outside water, unhook for the water drain the hose and use on board water overnight. Hook back up after the temp rises. I
About RV Newbies
4,032 PostsLatest Activity: Dec 23, 2025
